Mopar E-body Parts
Claudia
Ohio
If the part is listed below, it is still for sale.
If the part is not listed below, I do not have one currently for sale.
Open to offers, pictures available upon request.
Mopar Headlight Buckets (2) -- 50
70-71 Mopar Rallye Wheel Center Cap (one disk only) - 5
Mopar Front Shock Mounting Hardware Kit -- 10
‘65 - '74 Mopar B / E-body Brake Booster with Master Cylinder - 175
71 - 74 E-body / 71 - 73 B-body Steering Column Seal Retainer - 18
Mopar Fuel Line Hardware Kit - 15
E-body Torsion Bar Set (774 / 775) - 40
Mopar Electronic Ignition Module - 10
70-71 E-body Wiper Linkage Pivot -- 50
70-74 E-body Front Windshield Lower Trim Molding - 100
70-74 E-body Front Windshield Driver Side Lower Corner Trim Molding - 30
Floor Heat Shield (6' x 4') - 50
70-72 E-body 4 Speed Brake Pedal Pad - 5
70-74 E-body Standard Dash Light Bar - 50
E-body Rallye Dash Gauge Cluster - 750
70-74 Barracuda Weather Strip Channel Retainer Trim Set - 100
73-74 B-body Outside Mirror Gasket - 10
70 -- 74 E-body Ignition Switch (missing connector) - 20
70 -- 74 E-body Key Buzzer Switch (missing terminal ends) - 25
70 -- 71 E-body Ignition Key Lock - 25
70 -- 74 E-body Turn Signal Switch (missing connector) - 25
Mopar Late 60's Interior Door Handles LH (2) -- 10
Mopar Dome Light Assembly - 50
Decal Application Spray and Gel - 10
Holley Blue Electric Fuel Pump - 100
Mopar Trunk Lid Latch Striker - 20
B / E-body Trunk Lid Latch Striker - 25
Mopar Trunk Lid Latch - 25
70-74 Barracuda License Plate Light Lens (2) -- 20
70-74 Plymouth Barracuda Fuel Tank Filler Neck Tube - 40
71 Barracuda Chrome Grill Taillight Bezel Set- 50
All parts are available for local pick-up or shipping out of Ohio.
tim hamilton
frankfort ohio
looking for front brackets on a 73 challenger attaches from front panel to fender almost above high beams , would you have these?
thanks
