Mopar Parts Lot
Claudia
Ohio
Mopar Parts Lot - $650 OBO
Local pick up in Southwestern Ohio or shipping is available.
Paint Suits
Trunk Lid Latch
Trunk Lid Latch Striker w / Mounting Hardware
Trunk Latch Striker Plate
Exterior Rear Upper Corner Window Trim Piece (LH)
Exterior Rear Lower Window Trim Piece (RH)
Exterior Rear Lower Window Trim Piece (LH)
Quarter Window Roller Kit
Door Lock / Latch Rod Clips
Door Lock Link Rod (LH)
Door Lock Cylinder Gasket Set (2 gaskets)
Vinyl Decal Application Kit (spray and gel)
Dome Light Assembly
Chrome Door Lock Lever (set)
Armrest Pull Cup Bracket
Interior Door Handle (LH)
Window Crank Handle
Ignition Key Lock Cylinder w/ Keys
Key Buzzer Switch (missing terminal ends)
Ignition Switch (missing connector)
Exterior Mirror Gasket
Exterior Mirror Gasket Set
Exterior Mirror Screw Kit
Automatic Console Top Plate
Rallye Dash Gauge Cluster Woodgrain Fascia
Rallye Dash Switch Panel Woodgrain Fascia
Standard Dash Light Bar
Black Carpet Set
Floor Heat Shield (approximately 6' x 4')
Front Windshield Lower Corner Trim Molding (LH)
Windshield Wiper Pivot
Main Drive Wiper Arm Linkage
Clutch Pedal Support Bracket
Manual Master Cylinder Mounting Plate
Master Cylinder Brake Lines
Lower Steering Column Seal Retainer
Front Shock Mounting Hardware Kit
Horn (set)
Battery Tray Support Brace
Plymouth Emblem
