Mopar Parts
Claudia
Ohio
Mix of new and used parts.
If it is listed below, it is still available.
If it is not listed below, I do not have one for sale.
All prices are OBO, pictures / package deals available.
Mopar Performance Air Cleaner Base Plate - 15
Mopar BB Misc Hardware – 25
Mopar BB Valve Cover Gasket Set (rubber) - 25
Mopar BB Valve Cover Gasket Set (cork) - 10
Mopar BB Cylinder Head Springs, Retainers & Exhaust Valves Set - 75
Rocker Arm Shims (vertical and horizontal) - 25
Mopar BB Chrome Valve Cover Hold Downs – 20
Mopar BB Coil w / Mounting Bracket - 20
Radiator Cap – 5
Mopar BB / 727 Kick Down Linkage - 100
Mopar BB Timing Chain Cover – 50
Mopar BB Water Pump Gasket - 6
Mopar BB Camshaft - 50
BB Fan Clutch - 15
Mopar BB Fuel Pump Pushrod - 20
Mopar BB HP Exhaust Manifold Heat Riser - 120
66 - 72 B-body / 66 - 73 C-body / 70 - 74 E-body LH 440 Engine Support Bracket – 30
Mopar BB Fuel Pump Gaskets - 6
Mopar BB Flexplate – 35
Mopar BB Rear Main Seal Retainer - 25
Mopar BB Oil Pump Shaft - 30
Mopar BB Oil Pump – 40
Fram Oil Filter - 5
Mopar BB Oil Pickup Tube – 20 new
Mopar BB Oil Pickup Tube – 10 used
Mopar Headlight Buckets – 50
70-71 Mopar Rallye Wheel Center Cap (disk only) - 5
Mopar Front Shock Mounting Hardware Kit – 10
‘65 - '74 Mopar B / E-body Brake Booster with Master Cylinder - 175
71 - 74 E-body / 71 - 73 B-body Steering Column Seal Retainer - 18
Mopar Fuel Line Hardware Kit - 15
E-body Torsion Bar Set (774 / 775) - 40
Mopar Electronic Ignition Module - 10
70-71 E-body Wiper Linkage Pivot – 50
70-74 E-body Front Windshield Lower Trim Molding - 100
70-74 E-body Front Windshield Driver Side Lower Corner Trim Molding - 30
Floor Heat Shield (approx. 6' x 4') - 50
70-72 E-body 4 Speed Brake Pedal Pad - 5
70-74 E-body Standard Dash Light Bar - 50
E-body Rallye Dash Gauge Cluster - 750
70-74 Barracuda Weather Strip Channel Retainer Trim Set - 100
73-74 B-body Outside Mirror Gasket - 10
70 – 74 E-body Ignition Switch (missing connector) - 20
70 – 74 E-body Key Buzzer Switch (missing terminal ends) - 25
70 – 71 E-body Ignition Key Lock - 25
70 – 74 E-body Turn Signal Switch (missing connector) - 25
Mopar Late 60’s Interior Door Handles LH – 10
Mopar Dome Light Assembly – 50
Decal Application Spray and Gel - 10
Holley Blue Electric Fuel Pump - 100
Mopar Trunk Lid Latch Striker - 20
B / E-body Trunk Lid Latch Striker - 25
Mopar Trunk Lid Latch - 25
70-74 Barracuda License Plate Light Lens – 10
70-74 Plymouth Barracuda Fuel Tank Filler Neck Tube - 40
71 Barracuda Chrome Grill Taillight Bezel Set- 50
Claudia
Ohio
Pictures.
Rodee
Hi,
do you still have the E-Body Trunk torsion bars? (In good condition and works already?) would you send these to germany?
Thanks in front of all.
Claudia
Ohio
I do not have any trunk torsion bars for sale.
