Mopar Parts
Claudia
Ohio
Updated Parts List
Mix of new and used parts. If it is listed below, it is still available. If it is not listed below, I do not have one for sale. All prices are OBO, pictures / package deals available.
All big block:
727 Kick Down Linkage - 100
Miscellaneous Hardware – 25
Coil Mounting Bracket - 10
Coil Relocation Plate – 15
Cylinder Head Springs, Retainers & Exhaust Valves Set - 75
Rocker Arm Shims (vertical and horizontal) - 25
Chrome Valve Cover Hold Downs – 20
Valve Cover Gasket Set (rubber) - 25
Valve Cover Gasket Set (cork) - 10
Radiator Cap – 5
Timing Chain Cover – 40
Water Pump Gasket - 5
Camshaft - 50
Fan Clutch - 20
Fuel Pump Pushrod - 10
HP Exhaust Manifold Heat Riser - 125
66 - 72 B-body / 66 - 73 C-body / 70 - 74 E-body LH Engine Support Bracket – 25
Fuel Pump Gaskets (2) – 5
Flexplate – 30
Rear Main Seal Retainer - 30
Oil Pump Shaft - 30
Oil Pump – 40
Fram Oil Filter - 5
Oil Pickup Tube (new) – 20
Oil Pickup Tube (used) – 10
B / E-body Headlight Buckets (2) – 50
70–74 Challenger Fender to Core Support Braces – 30
70-72 B-body / 70-74 E-body Battery Tray Support Braces – 15 each
Front Shock Mounting Hardware Kit – 10
71-73 B-body / 71-74 E-body Lower Steering Column Seal Retainer - 20
Fuel Line Hardware Kit - 15
67–72 A-body / 66 - 70 B-body Starter Splash Shield – 45
70-74 E-body Main Drive Wiper Arm Linkage - 50
70-74 E-body Windshield Wiper Pivot – 45
70-74 E-body Front Windshield Lower Trim Molding - 75
70-74 E-body Front Windshield LH Driver Side Lower Corner Trim Molding - 30
Floor Heat Shield (approximately 6’ x 4’) - 40
70-72 E-body Automatic Brake Pedal Pad - 10
70-74 E-body Standard Dash Light Bar – 50
70-74 E-body Rallye Dash Switch Panel Fascia - 50
70-71 E-body Rallye Dash Fascia – 75 each
70-74 Barracuda Inner Drip Rail Trim Set - 80
73-74 B-body Outside Mirror Gasket - 8
70–74 E-body Ignition Switch (missing connector) – 20
70–74 E-body Key Buzzer Switch (missing terminal ends) - 20
70–71 A / B / E-body Ignition Lock Cylinder w / Keys - 25
70–74 E-body Turn Signal Switch (missing connector) - 25
Interior Door Handles (two LH) – 10 both
66-74 A / B / E-body Dome Light Assembly – 40
Vinyl Decal Application Spray and Gel – 10
60-74 A / B / E-body Door Lock Cylinder Gaskets – 5
70-74 E-body Door Lock Link Rod LH - 10
70-74 Dodge Challenger Rear Glass - 150
Holley Blue Electric Fuel Pump – 100
70–74 E-body Exhaust Tip Trunk Mounting Plate - 10
66-74 Mopar Trunk Latch Striker Plate - 20
68-74 B / E-body Trunk Lid Latch Striker - 25
62-74 B / E-body Trunk Lid Latch - 30
70-74 Barracuda License Plate Light Lens – 8 each
70-74 Barracuda Fuel Tank Filler Neck Tube – 45
70-72 Challenger Rear Bumper Guard Bracket Set - 30
71 Barracuda Chrome Grill Taillight Bezel Set- 60
