Mopar Parts
Claudia
Ohio
Let me know if you are interested in anything.
Engine Parts – All 440 Big Block
Miscellaneous Hardware – 25
Coil Relocation Plate – 15
Valve Cover Oil Fill Cap - 8
Chrome PCV Breather Cap – 8
Cylinder Head Springs, Retainers & Exhaust Valves Set – 75
Chrome Valve Cover Hold Downs – 20
Valve Cover Gasket Set (rubber) - 25
Valve Cover Gasket Set (cork) - 10
Radiator Cap – 5
Thermostat Housing Gasket w / Mounting Hardware – 5
Distributor O-ring Gasket - 1
Timing Chain Cover – 40
Heater Hose Nipple - 10
Water Pump Gasket - 5
Camshaft - 50
Fan Clutch - 20
Fuel Pump Pushrod - 10
HP Exhaust Manifold Heat Riser - 125
Engine Support Bracket (LH) – 25
Fuel Pump Gasket - 5
Flexplate – 30
Rear Main Seal Retainer - 30
Oil Pump Shaft - 30
Oil Pump – 40
Fram Oil Filter - 5
Oil Pickup Tube – 20
Car Parts
70 Road Runner / 70 GTX / 71 Barracuda Hood “Plymouth” Emblem – 30
B / E-body Headlight Bucket – 25 each
70-74 Challenger Fender to Core Support Brace Set - 30
70-72 B-body / 70-74 E-body Battery Tray Support Brace – 15 each
71-72 B-body / 70-74 E-body Inner Fender Inspection Cover (LH) - 15
Front Shock Mounting Hardware Kit – 10
71-73 B-body / 71-74 E-body Lower Steering Column Seal Retainer - 20
Fuel Line Hardware Kit (3/8” supply – ¼” return) - 15
67-72 A-body / 66-70 B-body Starter Splash Shield – 45
70-74 E-body Telescoping Antenna Mast - 20
Master Cylinder Brake Lines - 20
71-74 B / E-body Manual Master Cylinder Mounting Plate – 40
70-74 E-body Hood to Cowl Seal – 18 each
70-74 E-body Main Drive Wiper Arm Linkage - 50
70-74 E-body Windshield Wiper Pivot – 45
70-74 E-body Front Windshield Lower Corner Trim Molding (LH) - 30
Body Plugs – 30
Floor Heat Shield (approximately 6’ x 4’) – 40
70-72 E-body Automatic Brake Pedal Pad – 10
Heater Box White Rope Caulk - 5
70-74 E-body Standard Dash Light Bar – 50
70-74 E-body Rallye Dash Switch Panel Woodgrain Fascia - 50
70-71 E-body Rallye Dash Gauge Cluster Woodgrain Fascia – 75 each
70-74 Barracuda Inner Drip Rail Trim Set – 80
70-74 E-body Sill Plates – 15 each
71-74 E-body Exterior Mirror Gasket Set - 12
73-74 B-body Exterior Mirror Gasket - 8
70-74 E-body Ignition Switch (missing connector) - 20
70-74 E-body Key Buzzer Switch (missing terminal ends) - 20
70-71 E-body Ignition Key Lock Cylinder w / Keys - 25
70-74 E-body Turn Signal Switch (missing connector) - 25
Interior Door Handles (LH) – 5 each
Dome Light Assembly – 40
Vinyl Decal Application Kit (spray and gel) – 10
Door Lock Cylinder Gasket Set (2 gaskets) – 5
70-74 E-body Door Lock Link Rod (LH) – 10
70-74 E-body Door End Seal (LH) – 12 each
70-74 E-body Door Lock Pillar Seal (RH) – 12
70-74 Barracuda Rear Quarter Glass (RH) - 60
70-74 Dodge Challenger Back Glass – 175
70-74 Barracuda Exterior Rear Lower Window Trim Piece (LH) – 40
70-74 Barracuda Exterior Rear Lower Window Trim Piece (RH) – 40
70-74 Barracuda Exterior Rear Upper Corner Window Trim Piece (LH) – 40
Holley Blue Electric Fuel Pump – 100
Trunk Latch Striker Plate - 20
68-74 B / E-body Trunk Lid Latch Striker w / Mounting Hardware - 25
62-74 B / E-body Trunk Lid Latch – 30
70-74 Barracuda License Plate Light Lens – 8 each
70-74 Plymouth Barracuda Fuel Tank Filler Neck Tube – 45
70-72 Challenger Rear Bumper Guard Bracket Set - 30
71 Barracuda Chrome Grill Taillight Bezel Set- 60
RJHJR
Claudia;
Might you have a 1970 Challenger driver's side door latch?
Thanks, Bob.
SFEbody
Los Angeles CA.
I need a 70 Challe tail light trim bezel set, only looking for NOS or very good condition.
