motor mounts
RD73RT
restoring a 73 chal w/ a 360 engine. don't remember what the old mounts
looked like since it's been about 3 years that I tore it apart. my question is, are the biscuit type mounts the same thickness on the left as the right? I bought some from my local Napa store and there about a 1/4 inch difference. Is this correct or a mistake on Napa's end.
thanks , rd73rt
it is a mistake , most of the mounts are made in india or over in that area & quality control just isn't important , I would use a set of the poly lock mounts that cannot fail , they cost a lot more but you only buy them once
Thanks for the quick reply, poly's are quite expensive, so I bought the Mag-mounts instead. these mounts have a bolt thru it.
thanks again,
