No Brake lights and no rear turn signal on passenger side
Big AL
The Waters Edge, Worth, Illinois.
I went to put a glass fuse on my 70 Challenger R/T and find that the passenger side rear Brake lights and same rear turn signal don't work yet when I turn all the lights they all work
but not the Brake or turn signal on same side rear !.. the Drivers side brake light and turn signal work fine also I changed the Bulbs just to make sure !... Any suggestions ???
AUSTA
PERTH WA
Check the connections behind the drivers side kick panel also the steering column connecters do the hazard lights work turn them on & wiggle all the connections to see if it comes on
Mastertech
Replace your turn signal switch. The signal light is a flashing brake light and both are routed thru the signal switch. Common problem as the contacts wear out over time.
