oil pan 383 71 cuda
gbrx5
Putting on rear sump oil pan on 1971 383 engine any issues or concerns or things I should not buy in regards to clearance issues on a 1971 Cuda
Rear sump will sit on the K-frame. Ebodies are not rear sump. 60's though 80's big block truck and van are rear sump. Take some measurments.
Wait a minute, rear sump would clear the k frame but the center link of the steering would be an issue. Either way you have to stick with a center sump.
I know that a 6 qt '70 or '71 hemi pan will fit. For some reason my original '71 383 Challenger came from the factory with a 6 qt hemi pan on it and it has no clearance issues. 7 qts with the filter which is 2 qts more than the stock pan, I like it.
You may want to consider a low profile pan, like a Milodon, which has side kick outs for increased capacity (7 qt) while still having decent ground clearance.
