SOLD Parts Going to Carlisle
floyd
Getting things put aside for Carlisle and thought I'd pre-list some stuff here. Vendor space G-123/4/5 (right outside Bldg T). Pics on request. In-person deals preferred. Nats pick-up is also a possibility.
Original 2944450 Steel Wheel – Original paint and primer, dated 12/11/69. $550. SALE PENDING
Original AAR Air Cleaner – Very nice condition, original paint some light surface rust that should clean up without major pitting. Has reproduction block-off plate with correct wing nuts. $2000
NOS E-Body Rear Shock Absorbers (Pair) – Part number 3402415, correct for 1971 Cuda/Challenger with 340/383. $1500.
NOS 7260 U-Joint – Small Yoke, Part 2266909. OE correct “DETROIT” with no Zerk fitting. $200 SOLD
Original 1968-70 340 HP Exhaust Manifolds – Casting numbers 2863553 (LH) and 2863549 (RH). Media blasted and coated with Eastwood Factory Gray Hi-Temp Coating. LH manifold is as mint as they come, dated Nov 69. RH manifold has some minor pitting in the lower portions and the heat riser is missing (not plugged), has the casting number and "L2" stamped lightly on the reverse side. $750
Original 1970 ‘Cuda Rocker Gills - Evidence of minor repairs on the backside. Will need detailing but solid parts. $200
Pics on request. Thanks for the ad!
Cuda_mark
Hi Floyd - Can I see a picture of the rocker gills? Thanks.
toolmanmike
Super Moderator
Staff member
Iowa
Original AAR Air Cleaner – Very nice condition, original paint some light surface rust that should clean up without major pitting. $2000
Post some pics of what you are selling. It's in the sale rules. Thanks
floyd
450 Rim
