FOR SALE Parts Lot
Claudia
Ohio
Would like to sell it all as a lot but if you see something that you need or could use, send me a PM and we will work it out.
70 - 71 Roadrunner / GTX / Barracuda "Plymouth" Emblem
70 - 72 B / 70 - 74 E Battery Tray Support Brace
67 - 71 B / 70 - 71 E Horns
Front Shock Mounting Hardware
71 - 73 B / 71 - 74 E Lower Steering Column Seal Retainer
Master Cylinder Brake Lines
71 - 74 B / 71 - 74 E Manual Master Cylinder Mounting Plate
71 - 74 B / 70 - 74 E Clutch Pedal Support Bracket
70 - 74 E Main Drive Wiper Arm Linkage
70 - 74 E Windshield Wiper Pivot
70 - 74 E Front Windshield Lower Corner Trim Molding (LH)
Floor Heat Shield
70 - 74 E Standard Dash Light Bar
70 - 74 E Rallye Dash Switch Panel Woodgrain Fascia w / mounting plate
70 - 74 E Rallye Dash Gauge Cluster Woodgrain Fascia w / mounting plate
71 - 74 B / 70 - 74 E Automatic Console Top Plate
71 - 73 B / 70 - 74 E Exterior Mirror Screw Kit
71 - 74 E Exterior Mirror Gasket Set
73 - 74 B Exterior Mirror Gasket
70 - 74 E Ignition Switch (missing connector)
70 - 74 E Key Buzzer Switch (missing terminal ends)
70 - 71 E Ignition Key Lock Cylinder w/ Keys
68 - 76 A / 68 - 74 B / 70 - 74 E Window Crank Handle
Interior Door Handles (LH)
70 - 74 E Armrest Pull Cup Bracket
70 - 74 E Chrome Door Lock Levers
Dome Light Assembly
Vinyl Decal Application Kit (spray and gel)
Door Lock Cylinder Gaskets (2)
70 - 74 E Door Lock Link Rod (LH)
70 - 71 E Door Lock / Latch Rod Clips
70 - 74 E Quarter Window Roller Kit
70 - 74 Barracuda Exterior Rear Lower Window Trim Piece (LH)
70 - 74 Barracuda Exterior Rear Lower Window Trim Piece (RH)
70 - 74 Barracuda Exterior Rear Upper Corner Window Trim Piece (LH)
Trunk Latch Striker Plate
$550 OBO
