FOR SALE Parts Lot
Claudia
Ohio
B / E-body Parts Lot – $875 - Make an offer.
Used - Battery Tray Support Brace – 70-72 B and 70-74 E
Used - Front Shock Mounting Hardware Set
Used – Lower Steering Column Seal Retainer – 71-73 B and 71-74 E
New - Telescoping Antenna Mast
New – Two Speed Wiper Motor Harness – 71-72 B and 70-73 E
New – Wiper Motor Nuts – A, B, C and E
Used – Two Speed Wiper Motor – B and E
Used – Three Speed Wiper Motor – 68-71 B and 70-74 E
Used – Main Drive Wiper Arm Linkage – 70-71 E
Used – Windshield Wiper Pivot – 70-74 E
Used – Front Windshield Lower Corner Trim Molding (LH) – 70-74 E
New / Used – Floor Heat Shield
Used – Manual Windshield Washer Pump – 70-74 E
Used – Rally Dash Clock Reset Cable – 70-71 E
Used – Switch Panel Mounting Plate – 70-74 E
Used – Standard Dash Switch Panel Bezel – 70-74 E
Used – Rally Dash Switch Panel Woodgrain Fascia – 70-74 E
Used – Rally Dash Gauge Cluster Woodgrain Fascia – 70-71 E
Used – Standard Dash Heater Control Bezel – 70-74 E
Used – Metal Interior Trim Set – 70-74 Challenger
Used – Automatic Console Shifter Light – 70-74 E
Used – Shoulder Belt Retainer Clips – 70-71 E
New – Exterior Mirror Retainer Hardware Kit – 71-73 B and 70-74 E
New – Exterior Mirror Gasket Set – 71-74 E
Used – Exterior Mirror Gasket – 73-74 B
Used – Ignition Switch (missing connector) – 70-74 E
Used – Key Buzzer Switch (missing connector) – 70-74 E
Used – Ignition Key Lock Cylinder w / Keys – 70-71 E
Used – Window Crank Handle – 68-76 A, 68-74 B and 70-74 E
Used – Interior Door Handle (LH)
Used – Armrest Pull Cup Bracket – 70-74 E
Used – Door Lock Lever Set – 70-74 E
Used – Dome Light Assembly
New / Used – Vinyl Decal Application Kit (spray and gel)
New – Door Lock Cylinder Gasket Set
Used – Door Lock Link Rod (LH) – 70-74 E
New / Used – Quarter Window Roller Kit – 70-74 E
Used – Coat Hooks
Used - Exterior Rear Lower Window Trim Piece (LH) – 70-74 Barracuda
Used – Exterior Rear Lower Window Trim Piece (RH) – 70-74 Barracuda
Used – Exterior Rear Upper Corner Window Trim Piece (LH) – 70-74 Barracuda
Used – Trunk Latch Striker Plate
New – Hooded Paint Suits
Luis9995
I need 70-71 rallye gauges comeplete if possible but let me see pics of what you have and prices
Claudia
Ohio
SFEbody - I do not currently have a complete rallye gauge cluster for sale.
