Claudia
Open to offers:
Valve Stem Seal Set
Battery Tray Support Brace
Front Shock Mounting Hardware Kit
Lower Steering Column Seal Retainer
Tach Wiring Harness
Two Speed Wiper Motor Wiring Harness
Front Windshield Lower Corner Trim Molding (LH)
Floor Heat Shield (approximately 6' x 4')
Manual Windshield Washer Pump
Rally Dash Clock Cable
Switch Panel Mounting Plate
Standard Dash Switch Panel Bezel
Rallye Dash Switch Panel Woodgrain Fascia
Rallye Dash Gauge Cluster Woodgrain Fascia
Lower Dash Trim Corner (LH) (missing small piece)
Heater Control Bezel
Radio Surround
Lower Dash Trim Corner (RH) (repaired crack)
Rallye Dash Light Bar Lens Set
Metal Interior Trim Set
Rubber Sun Visor Tips
Shoulder Belt Retainer Set
Exterior Mirror Screw Kit
Exterior Mirror Gasket Set
Ignition Switch (missing connector)
Key Buzzer Switch (missing terminal ends)
Ignition Key Lock Cylinder w/ Keys
Interior Door Handle (LH)
Armrest Pull Cup Bracket
Door Lock Lever (set)
Dome Light Assembly
Vinyl Decal Application Kit (spray and gel)
Door Lock Cylinder Gasket Set (2 gaskets)
Door Lock Link Rod (LH)
Quarter Window Roller Kit
Exterior Rear Lower Window Trim Piece (LH)
Exterior Rear Lower Window Trim Piece (RH)
Exterior Rear Upper Corner Window Trim Piece (LH)
Trunk Latch Striker Plate
Paint Suits
Valve Stem Seal Set
Tach Wiring Harness
Radio Surround
Dome Light Assembly
Paint Suits
