Parts
Claudia
Ohio
Fresh update to the parts list.
Pictures available upon request.
New and used.
All OBO.
70 Road Runner / 70 GTX / 71 Barracuda Hood “Plymouth” Emblem – 30
B / E-body Headlight Buckets (2) – 50
70 – 74 Challenger Fender to Core Support Braces - 30
70-72 B-body / 70-74 E-body Battery Tray Support Braces – 15 each
71 – 72 B-body / 70 – 74 E-body Inner Fender Inspection Cover (LH) - 15
Mopar Front Shock Mounting Hardware Kit – 10
71 - 74 E-body / 71 - 73 B-body Steering Column Seal Retainer - 20
Mopar Fuel Line Hardware Kit (3/8” supply – ¼” return) - 15
67 – 72 A-body / 66 - 70 B-body Starter Splash Shield – 45
70 – 74 E-body Telescoping Antenna Mast - 20
Master Cylinder Brake Lines - 15
71-74 B / E-body Manual Master Cylinder Mounting Plate – 40
70 – 74 E-body Hood to Cowl Seal – 18 each
70-74 E-body Main Drive Wiper Arm Linkage - 50
70-71 E-body Wiper Linkage Pivot – 45
70-74 E-body Front Windshield Driver Side Lower Corner Trim Molding - 30
Mopar Body Plugs – 30
Floor Heat Shield (approximately 6’ x 4’) – 40
70-72 E-body Automatic Brake Pedal Pad – 10
Mopar Heater Box White Rope Caulk - 5
70-74 E-body Standard Dash Light Bar – 50
70-74 E-body Rallye Dash Switch Panel Fascia - 50
70-71 E-body Rallye Dash Fascia – 75 each
70-74 Barracuda Weather Strip Channel Retainer Trim Set – 80
71 – 74 E-body Exterior Mirror Gasket Set - 12
73 - 74 B-body Exterior Mirror Gasket - 8
70 – 74 E-body Ignition Switch (missing connector) - 20
70 – 74 E-body Key Buzzer Switch (missing terminal ends) - 20
70 – 71 E-body Ignition Key Lock - 25
70 – 74 E-body Turn Signal Switch (missing connector) - 25
Mopar Late 60’s Interior Door Handles LH – 10 for both
Mopar Dome Light Assembly – 40
Vinyl Decal Application Spray and Gel – 10
60-74 A / B / E-body Door Lock Cylinder Gaskets – 5
70-74 E-body Door Lock Link Rod LH – 10
70 – 74 E-body Door End Seals LH – 12 each
70 – 74 E-body Door Lock Pillar Seal RH - 12
70 – 74 Dodge Challenger Back Glass - 175
Holley Blue Electric Fuel Pump – 100
66-74 Mopar Trunk Latch Striker Plate - 20
68-74 B / E-body Trunk Lid Latch Striker - 25
62-74 B / E-body Trunk Lid Latch – 30
70-74 Barracuda License Plate Light Lens – 8 each
70-74 Plymouth Barracuda Fuel Tank Filler Neck Tube – 45
70-72 Challenger Rear Bumper Guard Bracket Set - 30
71 Barracuda Chrome Grill Taillight Bezel Set- 60
Mopar BB / 727 Kick Down Linkage - 100
Mopar BB Misc Hardware – 25
Mopar BB Coil Relocation Plate – 15
Mopar BB Valve Cover Oil Fill Cap - 8
Mopar BB Chrome PCV Breather Cap – 8
Mopar BB Cylinder Head Springs, Retainers & Exhaust Valves Set – 75
Mopar BB Chrome Valve Cover Hold Downs – 20
Mopar BB Valve Cover Gasket Set (rubber) - 25
Mopar BB Valve Cover Gasket Set (cork) - 10
Radiator Cap – 5
Mopar BB Thermostat Gasket w / Mounting Hardware - 5
Mopar BB Timing Chain Cover – 40
Mopar BB Heater Hose Nipple - 10
Mopar BB Water Pump Gasket - 5
Mopar BB Camshaft - 50
Mopar BB Fan Clutch - 20
Mopar BB Fuel Pump Pushrod - 10
Mopar BB HP Exhaust Manifold Heat Riser - 125
66 - 72 B-body / 66 - 73 C-body / 70 - 74 E-body LH 440 Engine Support Bracket – 25
Mopar BB Fuel Pump Gaskets - 5
Mopar BB Flexplate – 30
Mopar BB Rear Main Seal Retainer - 30
Mopar BB Oil Pump Shaft - 30
Mopar BB Oil Pump – 40
Fram Oil Filter - 5
Mopar BB Oil Pickup Tube – 20 new
Mopar BB Oil Pickup Tube – 10 used
