R/T 71
I looked around to see if this subject had been addressed before, but didn't find a satisfactory answer. The valve covers have a twist-in hole and a "knock-out" hole in each. I'm not too keen on putting another hole in one cover for a PCV valve. The twist-in holes have a baffle under them, so using one for oil filler probably won't work. A twist in breather for one side of the PCV system is obvious. Is there such a thing as a twist in PCV valve? I seem to remember Ford had a "closed" breather you could put a grommet and PCV valve into. I'm trying to not overthink this, but I'm out of ideas. Thanks in advance.
