Check the balance on those rear tires first. Very large tires are notorious for high speed vibration. Take it to your local trusted tire shop and watch for excessive runout of the tire/wheel or both when mounted to an off the car balancer . If the
runout is good, Check the dynamic balance on the tire ,wheel combo.
Put weights on both sides of the wheel to balance properly. Don't believe any one telling you that they can balance using weights on one side. In order to accomplish this,they set up the machine for a static balance. This ignores the reading on the outside of the wheel, giving you a false balance. When a tire hops up and down, it is telling you that it has a heavy spot on the tire/wheel but it doesn't tell you how much it is out on inside or out side. Dynamic balance fixes the wobble induced from the weight being off on the inside and outside of the tire/wheel combo. It is easy to make the machine say what ever you want, but once the tires are on the ground is the true test. You can also put your rear axle on jack stands and have someone in side the car to put it in gear, gradually increasing speed while you watch the tires from the side NOT the rear of the car for safety reasons.
Tell us what you find.
And go to the welcome wagon and introduce your self to the members on the site. A lot of experience out there, so join in. Welcome to the site.
Sorry about the duplicate post !
