Matt L.
- Joined
- Jul 23, 2020
- Messages
- 72
- Reaction score
- 24
Hello there, I'm getting ready to restore a 71 Cuda with a numbers matching 340 - 4 speed in it. Someone restored it in the early 90's and I bought it over 10 years ago. I'm trying to restore this and wanted to know what you guys think in order to make it more valuable.
When it was "restored" they put rear go wing on it, which isn't on the tag. In addition, it was originally dark metallic green and he had it painted red.
I have to pull the motor and have it redone in addion to taking care of the underside, which wasn't touched during the restoration.
I've gotten some parts for the restoration, such as new 15" wheels (era corrcect, but not the 14" on the spec sheet), thermoquad, jack, space saver tire, and recently purchased an air cleaner and valve covers (thanks to the guys that are sending them).
Some things I am considering and would like advice on.
I'd like to have A/C in the car, so would this degrade the value of the car if restored to original and possibly finding an OEM factory A/C from another car?
Should I repaint it to the factory original paint or leave it red?
What should I do to the underside of the car as far as paint or other treatment?
Should I remove the rear spoiler and have it as per the spec sheet?
I'd also like to make it power steering and possibly disc breaks, thoughts?
Negatives: there was a leak into the trunk and also into the rear drivers side floor pan which caused the bubbling of paint. The trunk has been fixed and repainted red, but there's still the issue I assume with the bubbling of paint in the rear driver's side floor panel. In addition, some mice got into it and tore up the headliner in a couple of spots, so I assume they are also in the duct system.
My goal is to get the best bang for my buck if I sell it, while at the same time being able to enjoy it if I decide to go for a cruise. I live in Texas, so A/C is a must.
Any thoughts on the value of the car as it sits, and what it would be worth fully restored?
Your advice is greatly appreciated.
Matt
Matt
