doubleyellow
Fuel Gauged pegged to Low side. When ignition "on" gauge needle moves very slightly up, but very, very little. Checked Ohms on Sending Unit (between sending unit post and ground) and reads about 25 Ohms. I believe that means there should be some fuel in tank (range about 10 Ohms tank empty to around 70 Ohms tank full ?). I did also check the ground strap straddling the fuel line.
Just from experience, is the fuel gauge needing to be repaired after 50 years? Have you rebuilt yours?
Or is the issue 99% of the time at the sending unit and I need to keep checking that (it was replaced 3 years ago, but could be faulty)
Any advice appreciated
