Claudia
Complete package is used and has around 500 total miles on it.
1.5 Ratio - Adjustable Aluminum Roller Rocker Package
Comes complete with the following components:
2 Main Rocker Arm Shafts
16 Aluminum Adjustable Rocker Arms
16 Adjusters
16 Adjuster Lock Nuts
Complete Aluminum Rocker Hold Down Set with Bolts (blue anodized billet aluminum)
Complete Main Rocker Shaft Spacer Set
Various thickness X, Y Directions Shims
Various Z Direction Shims
Two of the roller rockers have a flat spot (shown in the picture with an “X” on them) which was due to an oil clearance oversight when originally setting them up. Replacement roller rockers can be purchased for $24.95 each from 440 Source. No other known issues . . . just changed directions to a different setup. Asking $300.
16 Adjusters
