Recommended replacement clutch for my 70 Chall R/T Vert
presstech27
Lititz, PA
Soon, I will be pulling my trans from my Chall R/T Conv 383 4-speed for a rebuild and, while it's out, I want to replace the clutch. Car is street driven only and is completely stock right down to the ignition points. Suggestions?
McLeod is my first choice , if you have 10.5 " then 10.95" will bolt up & work better
Ram is another opttion , I prefer 3 finger Borg & Beck type , the cars were never designed for Diaphragm type
presstech27
Lititz, PA
Wow! Thank you! I installed a Centerforce diaphragm style clutch in my last car. The decreased clutch load on the pedal required the removal of the over center spring (which was a challenge). It worked well after that. That being said, I would rather keep things as the car was designed and proceed with your recommendation. Thanks so much!
I have nothing good to say about C force clutches , many problems with them
Destruction of the disc , pedal would stay on the floor on fast shifts & refuse to re-engage , the weights sticking / jamming in the fingers
toolmanmike
Super Moderator
Staff member
Iowa
Contact Brewer Performance. THey are the 833 experts. Brewer's Performance - Mopar A833 4-Speed Transmission and Component Specialists
Rons340
Tennessee
I used a McLeod set from Summit Racing in my 340/4 speed Challenger and have beed very happy with it!
