zeus
Hello all. Gutting the interior and cleaning up things on my project 'cuda. Both seat belts don't work. The retractors are stuck and the belts won't come out. I removed both the exterior housings, and can see the problem. Only those of you that have ventured this deep into these devices will understand, but basically the plastic peice with notches (that either blocks or pushes the flap that stops the retractor) is sliding with too much friction against the belt housing, so any movement on the belt causes it to make the flap stop the retractor. I only have 1/8th inch of room in there when I push them apart, got some wd40 in there and made sure there isn't any junk in there, but didn't relieve the friction at all. Any suggestions for how i can smoothen things out? I can't really get a dremel in there. I don't want to take the assembly further apart really, as I have no idea what's going to pour of there. Thanks for your advice!!
