Speedometer gear size
Ralph
What speedometer gear would i use for my 73 cuda ?
355 rear axle ratio with tires P235 / 60 R15 which is 26.1 high
I was thinking Red 36 teeth
What do you think ?
Thanks to all
R
340challconvert
Parsippany, NJ
Hope this helps!
Your tire 235-60R15 w 7.4 diameter 26.1
Gear Part # color
Tire Diameter
3.55 2538939 (Green) 24"
2538936 (Red) 26"
2538933 (Yellow) 28"
2538931 (Green) 30"
Please Note: These part numbers are for the standard style pinion gear. The last two numbers of the part number is the number of teeth for the gear (Example 2538943 = 43 teeth).
Here is an example on how to calculate the wheel diameter to select a speedometer gear to use with the desired ring/pinion gear.
Example
Tire Size: 245/60/15
245mm/25.4mm = 9.64 Inches Section Width
9.64 in. X 60% = 5.79 in. Side Wall Thickness
5.79 in. X 2 = 11.57 in. Total Side wall height
11.57 in. + 15 in. (Rim Size) = 26.6 in. Diameter
So with this Tire Size and 3.91 Gears, I would use a 40 Tooth Speedometer gear.
Looks like your calculation for the red gear as correct
Ralph
When I replace the speedometer gear will I lose alot of trany fluid or is it high enough not to plan for it. Is it easy to change ?
Mopars & Missiles
Put the back end up on jack stands (or higher than the front) to help keep the fluid up front. You won't loose much at all this way. Real easy to change the gear, pop out the old one and insert the new. Keep in mind to check and make sure the adapter is indexed correctly for your new gear before you close it back up.
