Squeaky Steering Column
Ricks72Chlgr440
Sisterdale, Texas
When I turn the steering wheel I hear a squeak like the bearings are dry. I know there is a bearing in the top of the column. What is the best way to lubricate that bearing short of disassembling the column?
Steve340
New Zealand
It could be the horn contact running dry - more likely than the bearings.
Remove the steering wheel and lubricate.
Ricks72Chlgr440
Sisterdale, Texas
Did you resolve your problem? If so what did you find?
Two things: where the horn contact touched the copper plate under the steering wheel was dry, so I put a VERY light coat of dielectric grease on the copper contact area. Second was the steering wheel was not tightened like it should have been. All nice and quiet now!
