340SHAKER
Hi guys, I finally got my car running. I installed the engine and transmission about 2 years ago. Now I have it running but the clutch doesn't seem to be working. I have the free play set correctly. I have the rear axle on jack stands. I start the engine in neutral and I cannot shift to any gear, it just grinds. I can start it in gear and the wheels spin free with no weird noises. However when I press the brakes with the clutch pedal pushed in it sounds like the clutch is chattering or grinding and I cannot stop the wheels from turning. I pulled the pan off and I can see the clutch relax when the pedal is pushed. Do you think the clutch disc is stuck on the flywheel? How would I free it up without removing the transmission? Thanks.
