T/A 340 long block for sale. Short block was rebuilt in 2001. T/A heads set aside and stored. Rebuilt standard J heads. The engine was bored .020, crank ground .010,
.010. eagle h beam rods installed. I have the original rods too. Bottom end balanced. The engine has low hours, but due to sitting years between being started the cylinders got moisture. And a cam lobe started to wear. Not sure if the torque plate honed .020 bores will clean up or need to bored .030? Two cylinders? The block is clean no sleeves or stripped threads.
The T/A heads do not appear to have had machine work done and have been magnafluxed. I have all the valves and springs but missing the keepers. The T/A rockers and shafts are in good shape. I also have the original push rods.
I am asking $8900. OBO
I am located outside of Portland Oregon
Thanks for looking
Thanks for looking
