Mmopars
I took this out of my 71 barracuda. it has at the most 50 miles on it..
$300.00 shipped in the U.S
four40cuda@yahoo.com
TCI Breakaway Torque Converter
Torque Converter, Breakaway, 11 in. Diameter, Chrysler, 727, 24-Spline, 2,400 Stall
The first step into serious high performance, the Breakaway® is a great torque converter for moderately modified street machines and weekend racers also used as daily drivers. It provides approximately 2400 to 2600 rpm flash stall with out negatively affecting part throttle driving. Designed for efficiency at highway cruising speeds and to launch hard at wide open throttle, the Breakaway® is a fantastic all-around torque converter.
Features: Furnace-brazed fins, Needle bearings, Hardened pre-ground pump hub, Computer Balanced, Installation hardware included
Benefits: Harder launches, Quicker acceleration, Improved low-end power, Bolt-in (no modifications required), 1000+ rpm increase in stall over stock
