Mopewbie
Hi all, I've been reading many threads about timing and would like to double check what to do in my car.
Stock 318 with a pertronix ignition.
I can't see the mark under any circumstances. I know the mark exists in the balancer but when I use the lamp, it's not aligned with the timing cover, can't see it at all.
I tried the lamp in all the cylinders and can't see the mark.
SO....
1- Bring it to TDC on Cyl1, both valves closed (compression stroke)
2- rotate the distributor until points to cyl 1
If I can't do that.... remove the distributor and manually (screwdriver) rotate the oil pump until it sets properly?
From the moment the car is on, to adjust timing I can't go on 2000 or 3000 RPM because I have no RPM counter. Have to rely on disconnecting vaccum and lamp ONLY.
Is that right? Car has an edelbrock and only starts if I hold the gas pedal down, like if it was flooded. (not flooded, that happens without pressing it before starting)
SO....
