Good morning,
I'm looking for some troubleshooting tips to help determine why my 1971 Challenger 440 6 pack/automatic will not start. Some background on the issue. The car was starting and running fine. While on a drive last weekend, the car randomly shut off while driving about 25-30 mph. There was no stumble or hesitation at all. It just turned off as if someone turned off the key. I pulled over and it fired right back up without issue. I continued on my drive of about 10 miles. Later on that night, it fired up without issue and I drove about 15 miles home. The following day, I went to start it and it would fire up, but as soon as I released the key from the start position, it would die right away. I suspected a fault ballast resistor. I ran a jumper wire from the positive battery terminal to the positive post on the coil. The car fired right up and stayed running even after releasing the key. In order to turn off the car, I removed the negative battery cable. The car was running for approx 3 mins before i shut it down with the neg battery cable. I removed the jumper wire and then picked up a new ballast resistor. I installed the new one and attempted to start the car. it would crank, but not start at all. I reinstalled the jumper wire and still it would crank and no start. I installed the old ballast resistor and still it will crank but no start. Any tips for troubleshooting this?
thanks,
Greg
thanks,
Greg
