V12T
70 Challenger. 512 stroker, 10.3 compression, stealth heads, ultralight crank, sixpack, modest street/strip Comp hydraulic lifter cam, headers (unknown brand), Mopar electronic ignition, 440 Source dist, new coil, new ballast (4 pin), 727 trans.
Engine running fine but trying to understand why I only have 9.5 volts at the coil. I have put a bypass wire on the ballast. The blue "run" wire has 11.8v when disconnected. When connected to the ballast (and therefore directly to the brown coil wire) the voltage falls to 9.5v at the coil. The blue wire is twinned with a light blue/yellow wire that goes to the ign. module. If I disconnect the ign. module plug, the coil voltage goes up to 11.8v. (not running now of course). Can anybody explain why the presence of the ign. module in the circuit cause the circuit voltage to drop? Is it perhaps meant to do this? Is there an alternative way to wire the ign. to get 12v at the coil which I assume is optimum?
