W2 head and intake part numbers.
Ohiowoodchuck
Anybody know the part numbers thru the years of the w2 heads and intake. I noticed older heads don’t have the same part number as the news listed at kegs or summit. This is for a stock block application. I’m hoping to find a set at the mopar nationals coming up.
gzig5
Mequon, WI
Good luck. There seemed to be dozon or more PNs for the heads and different casting numbers as well. Problem is that the PN is often times not on the head so you have to slueth out the features (valve angle, exhaust port pattern, rocker mounting, etc) to figure out what PN a head actually is. I was looking a couple years ago but it was getting confusing and frustrating because most sellers of used or NOS W2 heads didn't know exactly what they had. Intakes are less confusing because you can just look at the ports to tell what works with a W2.
