WTB Want to buy. 71 Door Glass components.
Gary Kitchens
Looking for the screws and paper washers, and Springsteel Nat has seen in this photograph
Mr Cuda
North of Seattle
Shipping is going to cost more than the parts.
You got the plastic slide on the other side that the screw goes through?
The paper washer is close to heavy roofing paper. Original paper probably won't make it through disassembly.
Gary Kitchens
I could really use that screw and the plastic pieces. I have a selection of gasket material that I can use to replicate the original tarpaper style gasket. And I already bought this piece of **** set off of eBay that they were advertising as factory original, 71 to 74 but as you can see from my photograph, it is definitely not the same thing as a quarter inch larger on all four corners, of my Chanel guides.
Gary Kitchens
Getting better pics of my needed parts in a half hour and I'll post again.
Gary Kitchens
OK, shown in the picture is the flat spring steel washer nut also shown is the aftermarket kit which does not conform in any way shape or manner to the original as you can see in the photograph the only parts that match are the black plastic pieces which I don’t need for my restoration. I just need the washer and the plastic insulator and the washer is the actual Matt I have the original screw still.
