JohnyChallenger
Hello everyone. I had a quick question I came into possession of a 1973 Dodge Challenger that has a 4 speed transmission out of a 1970 roadrunner & I was wondering what this red knob was beside my shifter. I posted
That's right,It slide up and down and stayed put. Correct?It's a Hurst Super Shifter with reverse lockout. The red lever - lockout, simply went up and down to engage and disengage. It did not require the use of two hands. The lockout was intended to prevent from accidently going into reverse while hard shifting. I had one of these in a Challenger. Never really found the lockout necessary. There were also, straight shifting rods which you could purchase / use with this shifter. However, the straight rods, relocated the factory shifter position higher on the transmission. The idea was to make the shifting more like a ram-rod / race setup.
As far as i know its an authentic hurst shifter. I believe its been answered by our fellow members. thank you! indeed reverse lockoutDoes it work? Remember it but not who made it.comes to mind Inland or Mr Gasket shifted? was it a knock off of hurst?
Thank you very much!It's a Hurst Super Shifter with reverse lockout. The red lever - lockout, simply went up and down to engage and disengage. It did not require the use of two hands. The lockout was intended to prevent from accidently going into reverse while hard shifting. I had one of these in a Challenger. Never really found the lockout necessary. There were also, straight shifting rods which you could purchase / use with this shifter. However, the straight rods, relocated the factory shifter position higher on the transmission. The idea was to make the shifting more like a ram-rod / race setup.
