Cuda tail panel emblem
aussiemark
Perth Western Australia
Just wondering what the story is with the Cuda tail panel emblem on the 70 model, mine has holes for 2 pins but all the emblems have tape. Should I just buy a repop with tape or is there one out there with the 2 pins?
704406
Shawnigan Lake B C Canada
70 'Cuda's had the 'Cuda script pt#3446960 adhered with tape, usually centred between the license plate opening and the trunk keyhole.
70 Barracuda's had a rectangular badge, with Barracuda spelled out inside it pt#2786559 secured with two pins with nuts on the inside behind the trunk lock protector shield.
Are the two holes in line with the trunk lock key hole?
If the holes are lower down, some dealers drilled holes to attach their name plates. Ive seen dealer name plates on both sides of the tail panel.
Hope this helps.
aussiemark
I had a better look and there are no holes it just looked that way from the outside I cleaned it and definitely no holes.
DetMatt1
Did this Cuda emblem go from stick-on to having pins at some point? Or the other way around?
