Driveshaft Angle Question
heminut
Deming, New Mexico
I spoke to a 4x4 shop and they said I can weld 1/4 of the spring perch starting at opposite corners letting the weld and axle housing cool between welds, they said the Dana 60 housing is thick enough they have never had a problem. I will use a miller 200 mig welder and let the weld and axle housing cool between welds, I'm also going to lay a wet towel on the end of the axle housing to keep heat from transferring toward the axle seal and bearing.
Thanks for the advice and info!
I think you will be just fine doing it like this.
cuda joe
nj
let us know how the welding in the perchs works out i got a b body 8 3/4 i was planing to do
Steve Blair
St Cloud, MN
I plan on welding tomorrow (depends on how early I can get started). I will let you know how it goes!
