BSG
- Joined
- Sep 26, 2018
- Messages
- 338
- Reaction score
- 70
Does anybody know off hand at what angle the engine and trans sit before you go changing everything and make your ebody shake at highway speeds. I just got to the point where I've narrowed it down to the drive line angles. After putting in that XV Motor sports suspension in. before selling it to you they don't tell you that the LA engine was an after thought and it was really intended for the newer hemi/magnum engines with the mounts further back so now the engine droops down in the front -1 degree with the poorly designed adapter brackets or literally tilted down in the front slightly. but im considering drilling out the perch's to raise the front up and drilling some holes at where the trans bolt goes mount back there I've tried shimming the diff 2 and 4 degrees and it just doesn't help. I'm also getting errors with the tremec driveline app as well. It doesn't look like I have any other options. If any knows the stock angle that would be great. would like to get it sitting like it started life would be a nice place to start. trying to make the Vegas trip this weekend with the motortrend guys. don't wanna be that dude on the side of the freeway with a drive shaft in his hand.
