Lunati hydraulic roller lifters
Slug
New york
I was thinking about buying a lunatic hydraulic roller cam and lifters. Anybody have any problems with the lunatic roller lifters?
Slug
New york
I should mention that I just ordered the new trick flow heads for the 340
Ele115
S. Fla
All I can say is that m ost of them get their lifters from the same place (China). You have to check everything when it arrives. Lifters, cam lobes, bearing journals, all of it before you install it no matter the brand, but especially the lifters. If you get one with no crown on it, you will lunch your engine.
heminut
Deming, New Mexico
Roller cams don't have a crown on the lobes, and I've never heard of crowns on lifters.
Mopar Nut
Roller lifters don't have a crown, they have rollers.
One of few
Michigan
I got a hold of a bad set from Comps, come to find out, my set was from a massive bad factory run. It took a couple of weeks, but they replaced the whole set.
Ele115
S. Fla
You have got to measure every last thing now. I know about rollers, but a lot of use aren't running them. They make it easier though. But you need to have crown on 16 lifters and taper on each lobe ...and each journal had better be right. If that lifter quits rotating that engine is gonna have to come back apart. It sucks, but the only one you can trust is yourself
Mopar Nut
The OP is not talking about flat tappet lifters, he’s talking about roller lifters.
