Manual disc brakes on a Challenger
1973dust
Illinois
I'm curious on others opinions of manual discs on a Challenger. I'm mostly curious about pedal effort without a booster, but if livable, the conversion would be a little simpler and less money with no booster. The car is currently 4-wheel manual drums.
Rapidfire
Culbertson Nebraska
I have manual disc on my 70 Challenger. A booster would be nice but after you get use to the manual brakes they work good IMO. You can always put a booster in later. Pedal effort is good if you use the right bore size in you master cylinder. JMO
6PKRTSE
I have manual disc brakes on my Challenger. However, they are Wildwood aftermarket brakes and master Cylinder. Stops just fine from 160+ MPH passes and work just fine in the street.
1973dust
Illinois
What do you consider the right bore size to be? Factory or other?
cuda joe
nj
I used a master cyl for a power disk brakes 74 dart when i added disk brakes on my cuda a little firm but stops great and i;m use to it
If you buy a matched conversion the proper M/C should come in the kit.
Things to consider for power brakes is how the engine is built as power brakes require a minimum amount of vacuum to operate properly. Also brake pedal/ Master Cylinder rod ratio.
