Top Dead Center
Lee W.
Newcastle Ca.
What is the best tool to buy to find top dead center with out tearing the engine apart ? 1972 440
You can feed a length of fuel hose in thru the spark plug hole and rotate it by hand until it stops. Mark the balancer where it happens to line up with zero. Then turn it the opposite direction until it stops and mark it. TDC is exactly between these two marks. You could also use a wood dowel or similar thing.
There are also piston stop tools that thread into the spark plug hole that work as Adam described that are not expensive
Lee W.
Newcastle Ca.
You can place it just inside th spark plug hole so it doesn't get crushed , just remember there is about 5* at TDC where the piston does not move
Xcudame
Southeast Arizona
The great thing about Mopars is they have a big rod to through ratio, so there is a long dwell time at Top Dead Center!
