K frame swap…anything on bolt threads?
JKCuda
Mechanicsburg, PA
Hey all…kind of a stupid question that I’m arguing with myself over and want some opinions. My Cuda rebuild is rapidly coming to a close and I’m putting the engine in. I have it on a QA1 tubular k frame and just need to lift it and install the bolts. The factory bolts were extremely rusty, like the rest of the inside of the rails, and I’m trying to decide if I want to put anything on the bolts. Anti seize, blue loctite, leave them dry?
Even though the factory installed them dry, I say coat them with blue loctite. That will dry and provide some corrosion protection.
I myself have had those conversations too. I always come to an intelligent conclusion by listening to me myself and I.
OH wait you want to converse about something else! RIGHT!
I always use anti seize on all suspension and brake mounting bolts. even if the bolts are plated. Ball joints a must. Clean rust from bolt thread chase threads with tap or other. You name it I put it there. Except wheel studs. NEVER had a problem in decades that I have been doing it. Doing this allows to achieve the correct torque. That's the important part.
JKCuda
Mechanicsburg, PA
OH wait you want to about something else! RIGHT!
Ok. That’s the way I was leaning but nice to know I’m not alone in that thinking, haha. I already cleaned the threads up so I’ll throw a little anti seize on the bolts and get this motor bolted in!
If you take notice to the thread they are cut. that bites into the other thread keeps them locked in per se.
Sorry, I stick by my loctite suggestion. Anti-seize in when you want to take it apart again (spark plugs) and loctite is when you want it to stay together. Wouldn't you want you k-member bolts to stay in? Use blue loctite to remove down the road if needed or red loctite if you want it locked semi-permanently.
