hpjunke
- Joined
- Nov 13, 2010
- Messages
- 167
- Reaction score
- 20
Ok Ive been having some inner tire wear on my 73 challenger and it’s starting to wonder a little bit so I decided I decided to take a look under It .When I Got it up in the air,checked everything related to steering and didn’t see anything at all that was loose or had any play in it. With the car off , I’m able to move the tires side to side a little like it has play and I believe that is normal . With the car running at idle, there isn’t any play at all . I even took the pitman arm off grabbed the arm and moved it side to side to check for play and there isn’t any at all. So my theory is that it needs an alignment to set toe etc since it’s been a while since its been done so I’m looking to set it up as follows
caster +4
camber -1 to 1.5 max
toe 1/16 to 1/8 in
Does this look like I’m on the right track or should I look at something else here?
thanks guys !
caster +4
toe 1/16 to 1/8 in
thanks guys !
