Power steering pump cooler
merkamp
Found a company that makes a power steering pump cooler for a 70 aar cuda
TIMINATOR
Avondale,AZ.
Why a P/S pump cooler anyway?
Trying to go resto, or do mopars need them?
Only one ford I had used one and no GMs that I have had so far. Are they needed for mopars?
TIMINATOR
Cuda_mark
I believe it was based on the gear ration that the car came with. 3.54 rear end or higher ratios got them. I could be wrong though
Juan Veldez
Nampa, Idaho
What does the rear end gear ratio have to do with power steering? Doesn't it have to do with a quick reaction steering ratio, or assuming it would be used in a road racing circuit. Maybe those cars had the low rear end gears? What am I missing?
Steve340
New Zealand
With the lower rear ratios the engine spins faster at any given road speed. This spins the power steering pump faster possibly overheating the power steer fluid.
TIMINATOR
Avondale,AZ.
Well then how do I figure out what if any damage has been done to my Duster with the 4.30 gears and 3000 stall convertor in the last 26 years of driving it here in Phoenix,AZ. where it gets to 115 degrees every summer? What should I check? The fluid smells fine...
I Would think that a cooler would be on a car sold here and not on a car in a cooler climate that just has a bit more gear.
I just think I am not gonna put one on my new build Challenger and see what happens.
TIMINATOR
Juan Veldez
Nampa, Idaho
Okay, that would make sense - thanks. I'd think they would put a different size pulley on the pump to slow it down, but a cooler would be simpler instead of having various pulley sizes maybe.
Steve340
New Zealand
If they slowed the pump down there may have been little or no power steering while the engine was idling.
TIMINATOR
Avondale,AZ.
My 72 p/s, p/b,a/c big block Chevelle had underdrive crank pulleys, and both the a/c and p/s worked fine. It did have 3.73 gears and a 3000 stall though. No issues at idle in a parking lot at all.
TIMINATOR
Vert
Maryland
I think the fins are uneven on originals. If you make them even, it'd be instantly identifiable as a repop.
