Big block headers with Power Steering
Fastguy444
Sebring, fl
Question does anyone know of Headers that bolt in to a 70 challenger big block with power steering? I've tried Hedman headers don't know the part number but they wouldn't work with my power steering . Thanks
1972 AAR Cuda
Washington state
I have had very good luck with TTI headers - I have used on big block, small block, E-body and A-body (small block) and I have been very impressed with the fitment and construction... the web site said it fits with power steering...
The only issue I have had is with shifter linkage, which they covered in their instructions.
TTI and Doug's 452 headers are the best fitting headers for Mopar. Doug's header length is shorter than the TTI headers.
Mopar Nut
Back in the day, when we didn’t have good choices.
Mopar Nut
I agree about Doug’s 452 (Call Doug’s to check fitment), right now Summit racing has them on sale, and if you can get a 10% off coupon, that’ll make it an excellent deal.
@Fastguy444 I would buy stainless steel if you’re going to keep your Challenger for a long time.
KlsCuda
Maine
Not sure if you got your headers sorted.. 70 Cuda 440 with Hooker competitions headers.. bit of "modification" required
Steve Blair
St Cloud, MN
I have a 71 Barracuda with a 512 stroker that has TTI headers with 2 inch primaries, 3 1/2 inch collectors, 3 inch exhaust and rectangular tail pipe tips through the tail pan that other than flattening the headers a tad where they came too close to my power steering sector (The header tubes were close so I did not want to risk a rattle with the engine running) everything fit perfectly. I did use pollyurathane motor mounts, and a pollyurathane transmission mount so the engine and transmission do not move. The car has a slap stick shifter that I made the link between the transmission shift lever and shifter because turning the factory shift lever upside down really did not work like the instructions from TTI showed. I also cut, overlapped and welded the shift bracket as outlined in the instructions from TTI. I'm very happy with how the headers and full exhaust installed from TTI. I did purchase Super Competition headers that I could not even get bolted to the heads so I returned them.
The car has a quick ratio pitman arm from PST that only works with the TTI 2 inch primary headers.
