FWI, this is right out of the installation manual for the Dakota Digital instrument cluster.
CONST. POWER
Connect the CONST. POWER terminal to a +12V power from the fuse panel that is “hot” all of the
time, or a fussed wire (5-20 amp) direct to battery power. This terminal should have power all of the time.
The constant +12V supply source should be a fused 5 - 20 amp circuit,
the system draws less than 1 amp,
so sharing an existing constant power circuit will generally be fine. Use 18 AWG wire to ensure the system
receives a sufficient power feed. This terminal keeps the clock memory as well as returning the needles to
zero when the system is shut off.
AUXILLARY CONNECTOR FOR BIM-SERIES
EXPANSION MODULES
MAN 650314
7
ACC. POWER
Connect the ACC. POWER terminal to accessory +12V power from the fuse panel or vehicle wiring
harness. This terminal should have power when the key is on or in the ‘accessory’ position. In addition to
turning on the instrument cluster, this is also where the voltmeter gauge senses the vehicle electrical
system voltage. The accessory +12V supply source should be a fused 5 - 20 amp circuit,
the system
draws less than 1 amp, so sharing an existing accessory circuit will generally be fine. Use 18 AWG wire to
ensure the system receives a sufficient power feed
