djlackore
- Joined
- Jun 4, 2016
- Messages
- 64
- Reaction score
- 3
Hey guys,
Not sure what is going on with my motor. It seems like this is happening more lately as i drive the car more.
Issue: When i drive everything is good but when i come to s stop and idle my motor tends to sputter and eventuality will die. Then i can start it no problem but when i shift into drive it will sputter then die or immediately die.
I thought this may be a heat issue boiling the gas so i placed a 160 t stat in there and also put on a heat deflector. Issue still occurs. One thing i noticed is that a spot on my fuel line before getting to the carb is sitting at 190-200 degrees.
Here is some video of the issue. It didn't die in the second and third video but you should be able to hear the sputter or see the shacking.
Thanks!
Thanks!
