7DCUDA383A
What do y'all use to clean the engine bay from leaking power steering fluid etc.
K frame mostlyOn the painted inner fender or on the K frame?
Easy-Off oven cleaner works well, keep off the aluminum parts, Rinse thoroughly.K frame mostly
I did see the Gunk , thanks Jack.I use Gunk engine cleaner on the engine and K member and 409 on the engine compartment painted surfaces. Then I use a garden hose to wash it away.
What's up RTA , just the power steering fluid when it went out , it traveled a good ways .Depends how bad it is. I have used gasoline in a few circumstance. Kerosene to remove heavy grease and oil. Next Gunk to de grease. Kerosene and Gunk are about the same thing. Followed by a cleaner such as purple power or simple green. The to remove any residue of any sort dish soap and water. I have also used a window cleaner for a very mild cleaning. Start with a cleaner that you think matches you needs.
Take note! When cleaning, clean from the bottom up to prevent streaking. Also keep a little wet or just damp to keep any stain from setting in. Then wipe from top to bottom.
Like I saidWhat's up RTA , just the power steering fluid when it went out , it traveled a good ways .
Do you know if I can use a brass plug for the pushrod hole , the plug that came out had some bad threads .Like I said
I didn't believe it until I tried it, but...Dawn foaming detergent works like a champ. It's bio-degradable and scrubs great. My Brother in law tuned me up on this. I laughed at first but now I am a believer.What do y'all use to clean the engine bay from leaking power steering fluid etc.
I cant find a black steel sunk plug and I didnt want aluminum , so brass is OK.Brass is fine,I always use a little thread sealer paste.
Yep all the time on lots of items! If you have not used this. Keep spending your hard earned cash on other cleaners.Anyone use warm water and Dawn .
It's not worth it! When the wife finds out you took it the price is much higher! Ask me how I know! What's yours is theirs and what theirs is theirs.Yep all the time on lots of items! If you have not used this. Keep spending your hard earned cash on other cleaners.
PLY478
