Looking for the part number for the rear shackle bushings that go into the P4452984 / 5 leaf springs.
The Moog K7309 is to small ID inside the spring.
Thanks in advance for any help!
Moog K7309 bushings are for A-body springs and have an outer diameter of 7/8". P4452984 springs require the 1" outer diameter bushing that was broadly used in Chrysler vehicles including C, B, E, and F bodies, B-vans, and more, but not A-bodies, nor R-bodies. Chrysler numbers are 1400269, 2403154, 3643989. The Harris number is HB-889 (or HB889). Also available as Jeep (pre-Chrysler) number 5355841, 3643989, 939797.
Some aftermarket numbers for rubber bushings are as follows:
- Moog K7308 (HR889 - individual bushing)
- Dayton HB889
- ACDelco 45G15405
- Mopar Performance P4452987
Mancini Racing MRE987A
- TRW HB889
- NAPA 274-8889
- NAPA Master Ride HB889
- Big A HB889
- McQuay-Norris SK8889
- AutoSpecialty 04-84514
- Raybestos 576-3405
- Mevotech MK7308
- International 165743R1, 166743R1
Also available at the following spring providers, among others:
General Spring: HB889 Harris Bushing (2 Required Per Eye)
Stengel Bros. Inc.: HB-889 Rubber Harris Split Bushing 1 O.D. 9/16 I.D. 1.6875 O.L. 1.25 I.L.
Eaton Detroit Spring 30HB889
Additional Details about HB-899:
A - Outer Diameter: 1.00 inch
B - Length: 1.25 inch
D - Inner Diameter: 0.563 inch (9/16 inch)
C - Length: 1.75 inch
E - Outer Diameter: 1.25 inch
