11" vs 10.5" clutch and bell housing
moparmaniac10
illinois
Can you use the 10.5" flywheel, clutch, and pressure plate with an 11" bell housing? Will there be an issue with the starter?
edison1970
Hampstead, NC
You need the flywheel with the greater number of teeth. Don't think the starter will engage with a smaller flywheel.
I agree , the 130 tooth flywheel needs the smaller belhousing , using the 143 tooth belhousing the starter sits further away from the flywheel .
the alum belhousing is the 130 tooth & uses the 10.5 or 10.95 " clutches , Cast iron belhousings are the 143 tooth & use only the 11" clutch ,
