2nd gear
KennyCuda
sometimes 2nd gear pops out I thought maybe a adjustment but doesn't look like it gotta be a syncro, The transmission has to come out to fix right ?
True , the trans has to be disassembled , the sliders , springs & the hub could all be worn
pschlosser
Santa Rosa, California
I've seen a condition where, once the transmission gets warm and hot, it pops out of 3rd on the highway and drops to 2nd and just won't go back into 3rd. That repair was deeply internal, and required pulling the transmission.
edit: I was referring to an automatic transmission. I think the OP is about a manny. my bad.
Steve340
New Zealand
Just double check there is no problem with the shifter or the adjustment. Check the fit of the shifter arms on to the shift forks - they all seem to get butchered there for some reason.
Check for worn or sloppy parts.
Can't hurt, if it only does it occasionally it may not be an internal problem.
Avalanche
Massachusetts
If you put a new rubber boot on your shifter, that might be the cause of the popping out of 2nd. Some newer rubber boots are hard and cause thus problem
