70 Cuda Console Wiring
0791ADUC 1970
texas
Are there any wires running to the center console in a 70 Cuda? If so where did they come from, straight down from the firewall or from the side by the rocker panel over to the console. Also what did they connect to, does it have its own harness? Thanks for any help!
fasjac
Arkansas
Can you share the problem if there is one or, something you’re trying connect to?
Like shifter indicator light?
I’m sure someone will send a schematic from service manual.
0791ADUC 1970
texas
I have a non-console 70 Cuda with a column shift. Im using a 70 console for cup holders a Tach and Oil pressure gauge. I’d like to run the wires to it the same way the factory did. I’ll add a picture when it’s complete.
fasjac
Arkansas
I understand, yea, share some pics when you get it buttoned up.
MoparCarGuy
To supplement what Challenger RTA posted for console wiring routing. The black tape is much like a paper masking tape. The wire is orange (ORG) insulation.
1970 HemiCuda Console Shifter Linkage and Light Wiring Passenger Footwell.jpg
0791ADUC 1970
texas
Thank you for the pictures, that’s very helpful. Because the orange wire runs the gearshift shift selector bulb light does that mean it will hook into the dimmer switch somewhere so it can be dimmed with all the dash lights?
