elnielsen
- Joined
- Nov 28, 2016
- Messages
- 63
- Reaction score
- 22
Hi all, my 71 Barracuda has a leaky tranny pan (one sealing section has a gouge, and the whole surface apparently is not flat enough, and I beat the crap out of the bolt holes). The cooler lines are "extended" with a 4" section of rubber tube (from the last owner). All attempts to stop the leaking have failed. Does anyone know where I can find the proper replacement tranny pan for the A-904-LA? And also the proper transmission cooler lines for a '71 Barracuda with 318 with the small original radiator and a904la? Summit had 8 they say will fit my car, each with it's own comments about this did/didn't fit my application.....
Side note, two backup switches and no reverse lights, any ideas?
This, after I removed it to replace the front pump seal leak.....
Thank you everyone!
Thank you everyone!
