Hello all,
Quick update for anyone who saw my intro, suspension is mostly squared away now and new torque strap installed. Ended up ordering new upper control arms cause my drivers side one is pretty bent and I wasn't able to replace the ball joint anyways without the socket. (In Japan, would have to order one anyways)
Onto my current issue! Lately, the car has been wreaking of gas but mostly from outside and even when it's been sitting for a day or 2. If it sits for more than 30 mins there's a 50% chance it will take tons of cranking to get it to finally turn over. Other times, it might fire right up. I'm not sure if my electric choke is acting up, but it definitely has a high idle when first starting so I don't think that's it. Also, I don't see any wetness or anything coming from the fuel pump/hoses after its sits so I don't think it's leaking. Timing is fine at least for idle, have it at about 14 degrees initial if I remember right when I set it a few months ago. Vacuum advance is turned way down but I still get a knock at higher rpms but I suppose that's a different question.
Anyways, any ideas on my gas smell and difficulty starting? Thanks on advance!
